The boot wizard will only run once when you firstly turn on Corbit, if you need to run it again, you need to select "SETTING"-->"System"-->"Reset options" -->"Erase all data (factory reset)" to restore the factory mode.
Please note that reverting to factory mode will erase all personal data of the user and revert to the initial state!
