Humiture Sensor
You can connect the [Humiture Sensor] block of mbuild to Halocode, and make more creations.
1. humiture sensor (1) temperature(℃)
Reports the temperature detected by the specified humiture sensor, measured in degree Celsius (℃).
Example
When the button of Halocode is pressed, the temperature detected by humiture sensor 1 will be displayed on blue LED matrix 1, measured in degree Celsius.
2. humiture sensor (1) temperature(℉)
Reports the temperature detected by the specified humiture sensor, measured in Fahrenheit (℉).
Example
When the button of Halocode is pressed, the temperature detected by humiture sensor 1 will be displayed on blue LED matrix 1, measured in Fahrenheit.
3. humiture sensor (1) air humidity(%)
Reports the air humidity detected by the specified humiture sensor.
Example
When the button of Halocode is pressed, the air humidity detected by humiture sensor 1 will be displayed on blue LED matrix 1.
0 out of 2 found this helpful
