button — Onboard Button
Function
button.is_pressed()
Get the current state of Halocode's button.
The returned result is True: the button is pressed; False: the button is not pressed.
Sample Code
import halocode
def loop():
while True:
if halocode.button.is_pressed():
print("button is pressed")
loop()
touchpad0 — Touchpad 0
Function
touchpad0.is_touched()
Get the current state of touchpad0.
The returned result is True: touchpad0 is touched; False: touchpad0 is not touched.
touchpad0.get_value()
If touchpad0 is touched, this function can obtain the strength of the touching.
The value range is 0-10000.
touchpad0.set_touch_threshold(val)
Set the threshold of touchpad0, parameter:
- val Percentage change of the touching; value greater than the threshold means being touched; the value range is 0-1.
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.touchpad0.is_touched():
halocode.led.show_all(126, 211, 33)
touchpad1 — Touchpad 1
Function
touchpad1.is_touched()
Get the current state of touchpad1.
The returned result is True: touchpad1 is touched; False: touchpad1 is not touched.
touchpad1.get_value()
If touchpad1 is touched, this function can obtain the strength of the touching.
touchpad1.set_touch_threshold(val)
Set the threshold of touchpad1, parameter:
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.touchpad1.is_touched():
touchpad2 — Touchpad 2
Function
touchpad2.is_touched()
Get the current state of touchpad2.
The returned result is True: touchpad2 is touched; False: touchpad2 is not touched.
touchpad2.get_value()
If touchpad2 is touched, this function can obtain the strength of the touching.
touchpad2.set_touch_threshold(val)
Set the threshold of touchpad2, parameter:
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.touchpad2.is_touched():
touchpad3 — Touchpad 3
Function
touchpad3.is_touched()
Get the current state of touchpad3.
The returned result is True: touchpad3 is touched; False: touchpad3 is not touched.
touchpad3.get_value()
If touchpad3 is touched, this function can obtain the strength of the touching.
touchpad3.set_touch_threshold(val)
Set the threshold of touchpad3, parameter:
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.touchpad3.is_touched():
pin0 — Pin0
Function
pin0.is_touched()
Get the current state of the pin.
The returned result is True: the pin is touched; False: the pin is not touched.
pin0.get_touchpad_value()
Obtain the strength of the touching. The value range is 0-10000.
pin0.set_touchpad_threshold(val)
Set the threshold of the pin, parameter:
- val Percentage change of the touching; value greater than the threshold means being touched; the value range is 0.0-1.
pin0.read_digital()
Read digital input of the pin. The value is 0 or 1.
pin0.write_digital(val)
Set digital output of the pin, parameter:
- val The value is 0 or 1.
pin0.write_analog(val)
Set PWM (Pulse-Width Modulation) output, parameter:
- val The value range is 0-1023.
pin0.read_analog()
Read PWM input. The value range is 0-3300, measured in mv.
pin0.servo_write(val)
Set the angle by which the servo motor turns, or the length of the pulse, parameter:
- val The angle of turning, the value range is 0-19999.
- When the value is less than 544, the result is to set the angle: if the input value is less than 0, the returned result is 0; if the the value is greater than 180, the returned result is 180.
- When the value is greater than or equals 544, the result is to set the length of the pulse, measured in us; the maximum value is 19999 us, nearly 20ms.
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.pin0.is_touched():
pin1 — Pin1
Function
pin1.is_touched()
pin1.get_touchpad_value()
pin1.set_touchpad_threshold(val)
pin1.read_digital()
pin1.write_digital(val)
pin1.write_analog(val)
pin1.read_analog()
pin1.servo_write(val)
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.pin1.is_touched():
pin2 — Pin2
Function
pin2.is_touched()
pin2.get_touchpad_value()
pin2.set_touchpad_threshold(val)
pin2.read_digital()
pin2.write_digital(val)
pin2.write_analog(val)
pin2.read_analog()
pin2.servo_write(val)
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.pin2.is_touched():
pin3 — Pin3
Function
pin3.is_touched()
pin3.get_touchpad_value()
pin3.set_touchpad_threshold(val)
pin3.read_digital()
pin3.write_digital(val)
- val The value is 0.0 or 1.
pin3.write_analog(val)
pin3.read_analog()
pin3.servo_write(val)
Sample Code
import halocode
import event
@event.start
def on_start():
global results
if halocode.pin3.is_touched():
motion_sensor — Onboard Motion Sensor
Motion Sensor Introduction
As shown in the picture above, the direction of the roll and pitch are based on the right-handed screw rule.
Both roll and pitch are 0° when Halocode is horizontally placed.
- Roll range: -90° ~ 90°
- Pitch range: -180° ~ 180°
Function
motion_sensor.get_roll()
Get the roll of the Euler angle, the returned data range is -90 ~ 90.
motion_sensor.get_pitch()
Get the pitch of the Euler angle, the returned data range is -180 ~ 180.
motion_sensor.get_yaw()
Get the yaw of the Euler angle, The returned data range is 0 ~ 360. Since Halocode's onboard sensor does not have electronic compass. So in fact the yaw angle is just the integral of the Z-axis angular velocity. It has accumulated errors. If you want to get a true yaw angle, this API is not suitable for use.
motion_sensor.get_acceleration(axis)
Get the acceleration values of the three axes in m/s^2, Parameters:
- axis String type, with x, y, z representing the axis defined by Halocode.
motion_sensor.get_gyroscope(axis)
Get the angular velocity values of the three axes in °/sec, Parameters:
motion_sensor.get_rotation(axis)
Get the angle at which Halocode rotates on the three axes, and the counterclockwise direction is the positive direction, parameter:
motion_sensor.reset_rotation(axis = "all")
The current angle of initial rotation around the three axes is 0, and the get_rotation() will start at 0, parameter:
- axis string type, with x, y, z representing the axis defined by Halocode, and all representing all three axes. This is also the default value for this function.
motion_sensor.is_tilted_left()
Check if Halocode is tilted to the left (threshold value is 15°), and the return value is a Boolean value, where True means that Halocode is tilted to the left, and False means that Halocode is not tilted to the left.
motion_sensor.is_tilted_right()
Check if Halocode is tilted to the right (threshold value is 15°), and the return value is a Boolean value, where True means that Halocode is tilted to the right, and False means that Halocode is not tilted to the right.
motion_sensor.is_arrow_up()
Check if Halocode is positioned arrow-up, and the return value is a Boolean value, where True means that Halocode is positioned arrow-up, and False means that the Halocode is not positioned arrow-up.
motion_sensor.is_arrow_down()
Check if Halocode is positioned arrow-down, and the return value is a Boolean value, where True means that Halocode is positioned arrow-down, and False means that the Halocode is not positioned arrow-down.
motion_sensor.is_shaked()
Check if Halocode is shaken, and the return value is a Boolean value, where True means that Halocode is shaken, and False means that Halocode is not shaken.
motion_sensor.get_shake_strength()
If Halocode is shaken, this function can obtain the intensity of the shaking. The value of the return value range is 0 ~ 100. The larger the value, the greater the intensity of the shaking.
Sample Code 1:
import halocode
import time
while True:
roll = halocode.motion_sensor.get_roll()
pitch = halocode.motion_sensor.get_pitch()
yaw = halocode.motion_sensor.get_yaw()
print("roll:", end = "")
print(roll, end = "")
print(" ,pitch:", end = "")
print(pitch, end = "")
print(" ,yaw:", end = "")
print(yaw)
time.sleep(0.05)
Sample Code 2:
import halocode
while True:
if halocode.motion_sensor.is_shaked():
print("shake_strength:", end = "")
print(halocode.motion_sensor.get_shake_strength())
Sample Code 3:
import halocode
while True:
if halocode.motion_sensor.is_tilted_left():
print("tilted_left")
if halocode.motion_sensor.is_tilted_right():
print("tilted_right")
if halocode.motion_sensor.is_arrow_up():
print("arrow_up")
if halocode.motion_sensor.is_arrow_down():
print("arrow_down")
led — Onboard LED
Function
led.show_single(led_id, r, g, b)
Set the displayed color one single LED, parameter:
- led_id The id of one single LED, the value range is 1-12, and the position of each LED is shown in the following image:
- r refers to the value of red component, parameter range is 0 ~ 255,0 with no red component and 255 the highest red component.
- g refers to the value of green component, parameter range is 0 ~ 255,0 with no green component and 255 the highest green component.
- b refers to the value of blue component, parameter range is 0 ~ 255,0 with no blue component and 255 the highest blue component.
Color – RGB Value Table:
red(255 , 0 , 0)
green(0 , 255 , 0)
blue(0 , 0 , 255)
yellow(255 , 255 , 0)
cyan(0 , 255 , 255)
purple(255 , 0 , 255)
white(150 , 150 , 150)
orange(255 , 50 , 0)
black(0 , 0 , 0)
gray(0 , 0 , 0)
led.show_all(r, g, b)
Set the color of all the LEDs, parameter:
led.off_all()
Turn off all the LEDs.
led.off_single(led_id)
Turn off one single LED, parameter:
- led_id The id of one single LEd, the value range is 1-12.
led.show.ring(color_str, offset=0)
Set the color of each LED at the same time, parameter:
- color_str String type, the format is "color1 color2 color3 color4"; "colorx" means "red"/"green"/"blue"/"yellow"/"cyan"/"purple"/"white"/"orange"/"black"/"gray"; over 12 colors will automatically be cut to 12.
- offset The value range is 0-12.
led.ring_graph(percentage)
Use the status of the LED ring to display percentage, parameter:
- percentage The value range is 0-100.
led.show.animation(name)
Show the default LED animation, parameter:
- name The four default LED animations: spoondrift, meteor, rainbow, and firefly.
led.is_led_ring_up()
Check if the LED ring is positioned face-up. The return value is True: the LED ring is positioned face-up; False: the LED ring is not positioned face-up.
led.is_led_ring_down()
Check if the LED ring is positioned face-down. The return value is True: the LED ring is positioned face-down; False: the LED ring is not positioned face-down.
Sample Code 1:
import halocode
import time
halocode.led.show_all(255,0,0)
time.sleep(2)
halocode.led.off_all()
time.sleep(2)
halocode.led.show_all(0,0,255)
time.sleep(2)
time.sleep(2)
halocode.led.show_all(0,255,0)
time.sleep(2)
time.sleep(2)
Sample Code 2:
import halocode
import event
@event.button_pressed
def on_button_pressed():
while True:
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white')
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 1)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 2)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 3)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 4)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 5)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 6)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 7)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 8)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 9)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 10)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 11)
time.sleep(1)
halocode.led.show_ring('red orange yellow green cyan blue purple white white white white white', 12)
time.sleep(1)
microphone — Onboard Microphone
Function
microphone.get_loudness(type)
Get the loudness, parameter:
- type String type: average, to get the average loudness over a certain period of time; maximum, to get the maximum loudness over a certain period of time; the value rang is 0-100.
Sample Code:
import halocode
halocode.microphone.get_loudness("average")
speech_recognition — Speech Recognition
Function
speech_recognition.start(server, language, time)
Start speech recognition, parameter:
- server Speech recognition server, the default server SERVER_MICROSOFT, powered by Microsoft.
- language The language of recognition: LAN_CHINESE, Chinese; LAN_ENGLISH, English.
- time The duration of speech recognition, the default value is 3 seconds.
speech_recognition.get_error_code()
Get the error code of speech recognition results, as follows:
0: correct
3300: wrong parameter
3301: ambiguous speech
3302: authentication failure
3303: original audio file or server problem
3304: user request override (QPS)
3305: user request override (PV)
3307: server problem
3308:audio content too long
3309: abnormal audio
3310:audio file too large
3311:wrong sample rate
3312: wrong audio file format
3333:unknown error
3334: response timeout
speech_recognition.get_error_message()Report specific error message, string type
speech_recognition.get_result_code()
Report recognition results, string type; return empty string when there is an error or a timeout condition.
speech_recognition.get_sn_code()
Report the single identification of voice data, generated by the server.
speech_recognition.get_all_respond()
Report the results of speech recognition, including all returned messages, like error message.
Sample Code:
import halocode, event
halocode.speech_recognition.set_recognition_url(halocode.speech_recognition.SERVER_MICROSOFT, "http://msapi.passport3.makeblock.com/ms/bing_speech/interactive")
halocode.speech_recognition.set_token(halocode.speech_recognition.SERVER_MICROSOFT, "ed8xubrmidv")
@event.start
def on_start():
halocode.wifi.start(ssid = 'Maker-guest', password = 'makeblock', mode = halocode.wifi.WLAN_MODE_STA)
while not halocode.wifi.is_connected():
pass
halocode.speech_recognition.start(halocode.speech_recognition.SERVER_MICROSOFT, halocode.speech_recognition.LAN_CHINESE, 3)
wifi — Onboard Wi-Fi
Function
wifi.start(ssid = "wifi_ssid", password = "password", mode = halocode.wifi.STA)
Start wifi connection, the API will not block process, API exit does not mean that wifi is connected, you need to call wifi.is_connected() to judge, Parameter:
- ssid string type, Wi-Fi account.
- password string type, Wi-Fi password.
- mode starts the Wi-Fi mode (currently only WLAN_MODE_STA)
wifi.is_connected()
Check if Wi-Fi is connected, the return value is Boolean, where True means that Wi-Fi has established a connection, False means that Wi-Fi has not yet established a connection.
Sample Code:
import halocode
import event
@event.start
def on_start():
pass
time.sleep(2)
cloud_message — Cloud Message
Function
cloud_message.start(topic_head, client_id=None, server="mq.makeblock.com", port=1883, user=None, password=None, keepalive=60, ssl=False)
Start sending cloud message, effective when Wi-Fi is connected, parameter:
- topic_head Prefix directory of cloud message topic.
- client_id The single client ID when connecting to proxy server; a random id will be generated when the string is empty or left unset, where the parameter clean_session of connect should be True.
- server Server name or IP address of remote server.
- *port* (optional) The port of the server to connect to; the default port is 1883.
- *user*_ (optional) The registered user name on the server.
- *password* (optional) The registered password on the server.
- *keepalive* (optional) Client's keep-alive value, default 60 seconds.
*ssl* (optional) Choose to support SSL/TLS.
cloud_message.get_info(message)
Report the additional parameters of cloud message, string or numerical type, parameter:
- message string type, the name of cloud message
Sample Code:
import halocode
import event
halocode.cloud_message.start('/USER/1014148/MESSAGE')
@event.start
def on_start():
pass
time.sleep(2)
halocode.cloud_message.broadcast('hello', '')
event — Events Function
Two Forms of Writing
One: registration form, as follows:
event.start(test_callback)event.received(callback, 'hello')
Two: decorator form, as follows:
@event.start
def start_callback():
print(123)
@event.received('hello')
def received_callback():
print(123)
Note: parameters other than "callback" need to be included.
Function
event.start(callback)
Startup event.
event.shaked(callback)
Halocode was shaken event.
event.button_pressed(callback)
Button pressed event.
event.tilted_left(callback)
Halocode left-tilted event.
event.tilted_right(callback)
Halocode right-tilted event.
event.arrow_up(callback)
Halocode arrow-up event.
event.arrow_down(callback)
Halocode arrow-down event.
event.received(callback, message_str)
Broadcast reception detection event. In addition to the callback parameter, the parameter:
- msgstr string type, the string to be matched. The event will be triggered when the received string matches the matching string.
event.cloud_message(message)
Cloud message event, parameter:
- message String type, name of the cloud message.
event.mesh_message(message)
Mesh message event, parameter:
- message String type, name of the mesh message.
event.greater_than(callback, threshold, type_str)
The threshold comparison event, which will be triggered when the threshold is exceeded. In addition to the callback parameter, the parameter:
- threshold value data, set the threshold for triggering.
- type_str string data, currently only supports sound_sensor: volume sensor, timer: timer.
event.less_than(callback, threshold, type_str)
Threshold comparison event, triggered below the threshold, in addition to the callback parameter, the parameter:
- type_str string data, currently only supports light_sensor: light sensor.
event.touchpad0_active(callback)
Touchpad0 event.
event.touchpad1_active(callback)
Touchpad1 event.
event.touchpad2_active(callback)
Touchpad2 event.
event.touchpad3_active(callback)
Touchpad3 event.
timer — Timer
Function
get_timer()
Get current value of the timer, measured in second.
reset_timer()
Reset timer.
variable — Variables
Function
set_variable(name, value)
Set variable, parameter:
- name The name of the variable.
- value The value of the variable.
get_variable(name)
Get information of the variable, parameter:
broadcast — Broadcast
Function
broadcast(message_str)
Broadcast a certain piece of message, parameter:
- message_str String type, the message to broadcast.
noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
