Stage—Sprites
Sprites are objects on the stage. You can operate a sprite by programming it.
Add a sprite
Click the Sprites tab and click + add.
If no sprite in the sprite library interests you, you can paint or upload your own sprite. On the Sprite Library page that appears, you can see Upload and Paint on the top.
Upload a sprite
Click Upload and select a file from the local disk in the window that appears.
Note: Currently, only JPG, PNG, and SVG files with a maximum size of 2 MB can be uploaded.
Draw a sprite
Click Paint.
Let's draw a house.
Name the sprite house, draw the first costume for it, and name the costume normal, as shown in the following figure.
16 out of 31 found this helpful
