Please refer to the following chart for detailed information.
mBot | mBot2 | |
Name | Name | |
Wheel hub | Plastic Timing Pulley 90T (4-Pack) | 90T Wheel |
Tyre※ | Slick Tyre 64*16mm (4-Pack) | 90T Tyre |
Head-replaceable screwdriver | Cross&2.5mm HEX Screwdriver 2.0 | Cross&2.5mm HEX Screwdriver 2.0 |
Mini wheel | Mini Caster Wheel | Mini Caster Wheel |
Motor※ | TT DC motor 6V/200RPM | 180 Optical Encoder Motor |
※Please be aware that the T-T electric DC motor is shared between mBot and mBot2.
However, the 180 optical encoder motor used in mBot2 is not compatible with mBot.
