6. Firmware Upgrade Fails
This guide applies to:
mBot2, mBot2 Neo, and CyberPi.
Routine Check
Refer to the quick steps below to rule out basic issues.
For details, please see this guide: Help Us Troubleshoot Faster
In a Nutshell
Step-by-Step
Possible Cause 1: Bluetooth adapter Is Used
Solution: If the firmware cannot be upgraded when the device is connected via Bluetooth adapter, please reconnect it through USB and try again.
Possible Cause 2: Wrong Device Selection
Solution: Check if you select the wrong device when connected. (mBot2 needs to connect CyberPi).
Possible Cause 3: mBlock 5 Software Bug
Solution: Go to the webpage of mBlock 5 and try to upgrade the firmware again.
Please be aware that the mBlock 5 webpage requires mLink. If it is missing, some functions may be affected.
If the firmware can be upgraded on the website, the mBlock5 software may have bugs. This issue can be solved by installing the up-to-date mBlock 5 software from our official website.
Possible Cause 4: Driver Faulty
Please refer to the article below to check if the driver works properly. If not, please download the CH340 driver from here. Uninstall the driver before installing the new one.
Troubleshooting CH340 Driver Issues
Download the CH340 Driver
Possible Cause 5: "Show All Connectable Devices" Checkbox Is Checked When Connecting Device
If yes, uncheck it.
Related Knowledge
How to Update CyberPi Firmware
Got Questions?
Feel free to contact us at:
service@makeblock.com
Help Us Solve Faster
We have listed some useful information you can provide to us. When you contact us, the more information you provide, the better informed we will be and the quicker we can advise and answer your questions.
0 out of 0 found this helpful
