21. The Servo Is Blocked
This article applies to:
mBot2, and mBot Neo.
Routine Check
Refer to the quick steps below to rule out basic issues.
例行检查图四张一组
For details, please see this guide: Routines for Troubleshooting CyberPi or mBot2 Issues
What You See
When you connect the steering servo to mBot2,
It moves as if something is blocked and makes a noise.
How to Solve it
The maximum twisting force of this servo is 1.5kg.
If the servo is overloaded, it will jitter or even get blocked at the tipping point.
The servo may be faulty, please contact service@makeblock.com for further advice.
Pay Attention
Running a locked steering engine for too long can damage it. The heat generated by the blocked engine can cause it to burn out and fail.
Note: A locked rotor occurs when a steering engine is overloaded and cannot rotate. A steering engine normally experiences a certain amount of resistance or load during normal operation, but if the resistance or load is too great, the engine will lock up.
When a locked steering engine is running, it may make abnormal noises or vibrate. It will also not be able to rotate as expected, which could cause the device or system to malfunction.
Got Questions?
Feel free to contact us at:
Help Us Solve Faster
We have listed some useful information you can provide to us. When you contact us, the more information you provide, the better informed we will be and the quicker we can advise and answer your questions.
0 out of 1 found this helpful
