19. mBot2 Won't Do Line-Following
This guide applies to:
mBot2 and mBot Neo.
Routine Check
Refer to the quick steps below to rule out basic issues.
In a Nutshell
When your device won't perform line-following as expected.
It's usually due to Quad RGB Sensor. Do the following steps.
  #1 Calibrate the Quad RGB Sensor.
  #2 Check if the Sensor is Faulty.
Step-by-Step
This is to make sure the sensor is adapted to your environment.
Factors like light condition and ground color will affect its performance.
Calibrate every time when you change to a new environment is recommended.
排障10-步骤图-1(校准
During steps 4~5 mentioned above, please check:
  If the indicators turn solid on white background, the calibration is OK.
  If the indicators keep flashing, please do the calibration again.
Move mBot2 to cross a line back and forth by hand and observe.
The indicators should stay solid in the background and turn off on the line.
If not, the sensor is likely to be faulty. Please contact customer support.
#3 Check the Line Following Function
1. Press Home Button on the left side.
Tap Switch Program, and press Button B
Push the joystick to the left to enter the programming interface.
Move down the joystick and select "mBot2_demo2".
2. Check if mBot2 follows the line properly.
If yes, the sensor may need to be calibrated again, or the line following program may be faulty and need to be improved according to the example program in mblock v5.4.0 app as shown in the photo below.
If not, the quad RGB sensor is faulty. Please contact service@makeblock.com for further advice.
Got Questions?
Feel free to contact us at:
Help Us Solve Faster
the better informed we will be and the quicker we can advise and answer your questions.
10 out of 12 found this helpful
