Build mBot Mega
Parts list
  • There are more than 30 parts in an mBot Mega with precise sheet metal processing technology, providing a beautiful and durable structure and making assembly easier.
  • It supports different types of sensors so that it can achieve more functions.
Assembly
Install the motor driver modules
Install the electronic modules onto the body shell
Install the left motor bracket
Install the right motor bracket
Install the line follower sensors
Connect the motor brackets
Install the body shell onto the motor brackets
Install an IR proximity sensor onto the upper shell
Connect all electronic modules to MegaPi
  • 3-pin connection mode provides more freedom. MegaPi is compatible with almost all 3-pin electronic parts, such as sensors, light strips, servos, etc.12_Connect_all_electronic.gif
Connect cables
Connection sequence of electronic modules
Positions of electronic modules
Connect motors
Install the battery holder (hidden installation method)
Tip: If you find it hard to replace the batteries after installing the battery holder in the way as described above, you can install the battery holder in another way, as shown in the following image.
Dimensions: 192 mm x 163 mm x 102 mm
Weight: 0.8 kg (without battery)
32 out of 41 found this helpful
3 comments
  • One Problem with these instructions was installing the two outside Proximity Sensors was not covered. The Step was missing completely from the instructions. The Upper Shell Proximity Sensor was the only one covered. It required me to take the shell off  the bottom M4x20 Nylon Standoffs to insert the screws.
  • Regarding the Battery case, I found that by slightly modifying the original battery case bracket by putting it in a vice and bending the 90 degree angle and making it about a 45 degree angle I was able to mount it to the top using the original bolt from the Upper Shell, it sits nicely and conforms to the angle of the rear body.
  • Thanks for your advice! (Addressing @Donald Chovanec)
    You can post about it on the forum if you like:
    forum.makeblock.com
