Get Started on mTiny
This page describes some basic operations on mTiny and the tap pen controller. Read it carefully if you use the mTiny robot kit for the first time.
Charge mTiny and the tap pen controller
Buttons on the tap pen controller
1: Power button
Long press the button to turn on or turn off
2: Confirm button
Press the button to run the input program, or repeat the last program.
3: Stop button
Press the button to stop the action in progress.
Turn on/turn off
1. To power on mTiny, turn the knob clockwise until you hear a click sound.
Note: After turning on mTiny, you can rotate the knob to adjust the volume.
2. To power on the tap pen controller, press and hold the power button for 2 seconds.
Note: Press and hold the power button (about 2 seconds) until all indicator lights turn off to power off the tap pen controller.
Enable/disable the joystick
In the mTiny Discover Kit, the joystick of the tap pen controller is disabled by default. To use the joystick to control mTiny, you need to enable the joystick first.
In the mTiny Coding Kit, the joystick of the tap pen controller is enabled by default. You can use it to control mTiny directly.
Hold down the power button, confirm button, and stop button at the same time to enable or disable the joystick of the tap pen controller.
Pair mTiny with the tap pen controller
Before pairing, restart mTiny and the tap pen controller. Then complete the pairing as follows:
1. Press and hold the two buttons for 2 seconds.
2. Move the tap pen controller close to mTiny to start pairing.
The indicators blink alternately in blue and red.
After the pairing is successful, the indicators are steady on in blue.
Status indicators
Status indicator of mTiny
Blue breathing light
In sleep mode
Note: After mTiny enters the sleep mode, you can move the joystick on the tap pen controller or shake mTiny to wake it up.
Red breathing light Charging
Steady on in green Charging completed
Blinks in red
Low battery
Note: To check the battery level of mTiny, tilt mTiny and hold it for a while. mTiny displays the battery level of both mTiny and the tap pen controller.
Blinks in blue Not paired with the tap pen controller
Blinks alternately in red and blue
Pairing with the tap pen controller
Steady on in blue Pairing succeeded
Status indicator of the tap pen controller
In sleep mode
Note: After the tap pen controller enters the sleep mode, you can move the joystick on it wake it up.
Blinks in red
Low battery
Note: To check the battery level of the tap pen controller, tilt mTiny and hold it for a while. mTiny displays the battery level of both mTiny and the tap pen controller.
Blinks in blue Not paired with mTiny
Pairing with mTiny
Control mTiny with the joystick
Push the joystick in different directions to move mTiny.
Use maps and cards
Use the maps and cards included in the map pack by referring to the storybook "mTiny and His Friends."
Map pack
Themed maps
Coding cards
Activity cards
Game cards
For details about the coding cards, see Using Coding Cards.
Make mTiny up
Use the masks and flags included in the map pack to make mTiny up.
Masks
Flags
Put a marker into the pen slot of mTiny
1. Take out a marker delivered with the mTiny robot kit.
2. Rotate the cap of the marker to open it.
3. Place the marker.
(1) Press the cover of the pen slot down to unlock it and take it out.
(2) Put the marker into the pen slot.
(3) Put the cover back and press it down to lock it.
12 out of 13 found this helpful
