Safety Instructions on Codey Rocky
Precautions
  • Recommended for children of age 6 or older.
  • Keep the product away from children under age 3.
  • Children should be accompanied by adults when using the product.
  • Do not place the product high on the edge of anything. Otherwise, it may be damaged due to falling down.
  • Do not place the product in water, fire, or high-humidity or high-temperature environments. Otherwise, it may be damaged or cause safety incidents.
  • Do not disassemble, repair, or modify the product by yourself. Otherwise, it may be damaged.
  • Do not use or charge the product in environments where the temperature is outside the operating temperature range. Otherwise, the product may be damaged.
  • Fully charge the product before you put it away for storage and recharge it once every 3 months if it is left unused.
  • Use adapters of 5V/1A to charge the product.
  • Power off the product and disconnect it from any external power supply before you clean it with any kind of liquid.
  • Connect the product to only one 5V power supply at a time.
  • Check the wires, plugs, housings or other parts periodically and stop using them if any damage has been found until they are well repaired.
Specifications
Item
Specification
Battery
950 mAh lithium battery
Output voltage of the Pogo Pin magnetic interface
DC 5V
Output current of the Pogo Pin magnetic interface
< 2A
Input voltage of the Micro USB port
DC 5V
Input current of the Micro USB port
1A
Transmission mode
Wi-Fi / Bluetooth / USB
Bluetooth distance
Within 10 meters (empty areas)
Wi-Fi distance
Operating temperature
0°C–40°C
Storage temperature
–10°C – +55°C
Pay attention to the distance and temperature when operating or storing Codey Rocky.
1 out of 3 found this helpful
