mBot Neo provides eight preset programs, which can be used after you building it.
1. Restart mBot Neo
Before running a preset program, turn mBot Neo off and then turn it on to ensure that it is restarted.
2. Enter CyberOS
CyberPi automatically enters CyberOS after you restart mBot Neo. If it doesn’t , press the Home button on CyberPi.
3. Choose and execute a program
Take program 1 as an example.
Move the joystick down to choose Switch Program, choose Program1, and press button B to execute the program.
About program 1
Program1 provides three operation modes. The path design mode is the default mode, and you can press button A on CyberPi to switch between them.
① Path design |
② Obstacle avoidance | ![]() |
③ Line following |
Mode 1: Path design
In path design mode, the LEDs on CyberPi are lit up in red, and you can use the joystick to plan the path.
(1) Move the joystick to plan the running path of mBot Neo.
For example, move the joystick up, to the right, down, and then to the left.
The path you have planned is displayed on the screen of CyberPi.
(2) Press button B on CyberPi.
mBot Neo runs in the path you have planned.
Mode 2: Obstacle avoidance
In obstacle avoidance mode, the LEDs on CyberPi are lit up in green.
mBot Neo automatically detects obstacles while running. When it detects an obstacle, it turns left or right.
Mode 3: Line following
In line following mode, the LEDs on CyberPi are lit up in blue.
In this mode, you need to use the map delivered with mBot Neo.
Place mBot Neo on the map and press button B on CyberPi.
mBot Neo automatically follows the black line.
Have more fun with the preset programs
1. Press the Home button to go to the homepage. |
we bought mbot2 and put it together in detail according to the instructions, but when we started it and set it to demo2 (avoidance of obstacles) mbot2 just spins in a circle, when we set demo3 and set the movement path with the arrows, it spins again only in a circle
