Program Ultimate 2.0 with mBlock 5
You can visit https://mblock.makeblock.com/en-us/ to download the block-based programming software you need.
Program with mBlock 5
mBlock 5 version
Required software
URL address
PC client on Windows/Mac
mBlock 5 for Windows
mBlock 5 for Mac
N/A
 Web version on Windows/Mac
Google Chrome
mLink2 for Windows
mLink2 for Mac
https://ide.mblock.cc
Web version on Chromebook
mLink for Chromebook
For details about how to use mBlock 5 to program CyberPi on Chromebook, see "Programming CyberPi on Chromebook."
2. Open the mBlock PC client and add Ultimate 2.0
3. Connect Ultimate 2.0 to mBlock 5
(1) Use the USB cable to connect your Ultimate 2.0 to your PC.
(2) On mBlock 5, click Connect.
After Ultimate 2.0 is successfully connected to mBlock 5, you can start to program it by dragging blocks to the scripts area.
For more details about how to use mBlock 5, see mBlock 5 Online Help.
Example programs
You can learn block-based programming by using the example programs.
Download an example program and double-click to open it to see how the program is compiled.
No. Form Example program
1 Robotic Arm Tank 01_Robotic Arm Tank-example
2 Beverage Robot 02_Beverage Robot-example-mblock 5
3 Camera Dolly 03_Camera Dolly-example-mblock 5
4 3D Capture A 04_3D Capture A-example-mblock 5
5 3D Capture B 05_3D Capture B-example-mBlock 5
6 Detecting Robot
06_Detecting Robot_line following_mblock 5
06_Detecting Robot_obstacle avoiding_mblock 5
06_Detecting Robot_remote control_mblock 5
7 Rolling Tank 07_Rolling Tank_mblock 5
8 Self-Balancing Robot 08_Self-Balancing Robot-mblock 5
9 Robotic Ant 09_Robotic Ant-mblock 5
10 Catapult Ram 10_Catapult Ram-mblock 5
Program with mBlock 3
2. Download the programming guide for mBlock 3
Download Guide (PDF)
Some Examples
Drag the module block you need from Robots Area, select the correct port/pin.Then trigger the running event, you can see it works.
  • Control DC Motor
  • Control  Me 7-segments Display
  • Read the value of Me Temperature Sensor
  • Control the Me RGB LED
Example programs
1 Robotic Arm Tank 01_Robotic Arm Tank-example-mblock 3
2 Beverage Robot 02_Beverage Robot-example-mblock 3
3 Camera Dolly 03_Camera Dolly-example-mblock 3
4 3D Capture A 04_3D Capture A-example-mblock 3
5 3D Capture B 05_3D Capture B-example-mBlock 3
6 Detecting Robot
06_Detecting Robot_line following_mblock 3
06_Detecting Robot_obstacle avoiding_mblock 3
06_Detecting Robot_remote control_mblock 3
7 Rolling Tank 07_Rolling Tank_mblock 3
8 Self-Balancing Robot 08_Self-Balancing Robot-mblock 3
9 Robotic Ant 09_Robotic Ant-mblock 3
10 Catapult Ram 10_Catapult Ram-mblock 3
11 out of 27 found this helpful
