Program Ultimate 2.0 in Python
Download the Arduino library for Makeblock https://github.com/Makeblock-official/Makeblock-Libraries/archive/master.zip
Copy the makeblock folder to your Arduino default library. Your Arduino library folder should now look like this
  • (On Windows): [x:\Users\XXX\Documents]\Arduino\libraries\makeblock\src
  • (On Mac OSX): [\Users\XXX\Documents]\Arduino\libraries\makeblock\src
Open Arduino IDE, click File > Examples and select the firmware.
Compile and upload firmware according to your board type.
Prepare for Raspberry Pi
On your Raspberry Pi, disable the login prompt from Desktop > Menu > Preferences > Raspberry Pi Configuration.
Install Python library for Makeblock
sudo pip install megapi
The initial code for python:
from megapi import *
bot = MegaPi()
bot.start() #if using usb cable, need to call bot.start('/dev/ttyACM0')
Start to write your py. file.
Wiring
Use MegaPi.
Use Me Shield for Raspberry Pi and RJ25 cable for Me Orion or Me Baseboard.
Note: By default, no connector for Raspberry Pi is provided on MegaPi. To connect to Raspberry Pi, you need to weld the connector (2 × 10 pins) on MegaPi first. Avoid short circuit during the welding.
Use a USB cable for Me Orion or Me Baseboard.
See the source code at https://github.com/Makeblock-official/PythonForMegaPi
3 out of 16 found this helpful
2 comments
  • Hi,
    Can you provide a video and/or further exaplanations and examples of the hardware required (Rpi versions, required connections, wireless options...) to program the Ultimate with Python?
    Regards
  • why the site of makeblock don't play??
