Case 9 - Access the Internet
Part 1   Objective
After you upload the program, you can connect CyberPi to the Internet and make it read "Hello World".
Part 2   Preparation
  • CyberPi x 1
  • USB cable (Type-C) x 1
Connect CyberPi to the computer by using the cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3   Programming
Find AI in the column and drag the blocks you need to the scripts area.
Note: Reading function needs access to the Internet. Ensure that the Wi-Fi network to which CyberPi is connected is working properly. Otherwise, CyberPi may read the texts slowly or even fail to read them.
Part 4   Practice
After being connected to the Internet, CyberPi can not only read texts but also recognize speech. Have a try!
5 out of 13 found this helpful
2 comments
    Eduardo Fernandes , you need to be in Upload mod and to be connected, if they are still grey after that then I don't know, sorry
  • In AI mode, i can not sellect some commands... why? (those related with speetch)
    -1
