About Me Shutter
Overview
Me Shutter is a special module designed to implement automatic photography for digital SLR cameras. Users can use it to take high-speed photos, or take time-lapse videos and photos with the intervalometer. The blue tag on the interface of this module indicates that it is a dual digital interface, it should be connected to a port with the blue tag on the main control board, and it should be connected to a camera with a dedicated cable.
Specifications
  • Operating voltage: 5V
  • Control mode: Dual digital interface
  • Dimensions (L x W x H): 52 mm x 24 mm x 18 mm
Features
  • The module can be used to control the camera shutter and focus;
  • The module can be used with different types of cameras;
  • The module features a short time delay, good performance, and a strong anti-interference ability;
  • The white zone on the module is for connection with metal beams;
  • The module supports programming in Arduino IDE, and simplifies the programming process with a runtime library;
  • The module supports block-based coding on mBlock 5 and mBlock 3, which is suitable for all ages;
  • The connection is easy with RJ25 connectors;
  • The module features modular installation, compatible with Lego parts;
  • The module has pins that support most Arduino main control boards.
Pin Definition
The connector of Me Shutter has 4 pins. The features of the pins are shown in the following table.
SN Pin Feature
1 GND Connect the ground electrode
2 VCC Connect the power cord
3 S Control the camera shutter
4 F Control the camera focus
Wiring Mode
● RJ25 cable
The tag color on the interface of the line follower sensor is blue. When you use an RJ25 connector, you need to connect it to a port with the blue tag on the main control board. Take Makeblock Orion as an example. You can connect it to port 3, port 4, port 5, or port 6 as shown in the following figure.
● Dupont cable
When you use a Dupont cable to connect to Arduino Uno, pin S and pin F of the module should be connected to digital interfaces as shown in the following figure.
Programming Guide
● Program with mBlock 5
Me Shutter supports programming with mBlock 5. The following is a brief description of a block on the module:
Block Features
output__24_.png Select a port
Set the function of the module (press shutter, relese shutter, start focusing, or stop focusing)
● Program with mBlock 3
Me Shutter supports programming with mBlock 3. The following is a brief description of a block on the module:
Block Features
output__25_.png Select a port
● Program in Arduino
If you program in Arduino, you need to use Makeblock-Library-master to control the Me Shutter.
Through Arduino programming, the following program can instruct the camera to take time-lapse photos when the camera receives the corresponding signals.
Function Feature
MeShutter(uint8_t port) Select a port
void shotOn() Output a low voltage to the camera shutter
void shotOff() Output a high voltage to the camera shutter
void focusOn() Output a low voltage to the camera focus
void focusOff() Output a high voltage to the camera focus
The camera can take time-lapse photos with the control of the camera shutter and focus.
Schematic
6 out of 8 found this helpful
