About TT Geared Motor DC 6 V / 200 RPM (for mBot)
Overview
TT geared motor DC 6 V / 200 RPM is a power source with plastic gears. The TT geared motor perfectly works with Makeblock plastic timing pulley 62T and plastic timing pulley 90T for wheel systems of DIY projects. It can be used to power mBot.
Features
  • It can rotate clockwise and counterclockwise.
  • It has a simple structure and its maintenance cost is low.
Specifications
  • Rated voltage: 6 V
  • No-load speed: 200 ± 10% (RPM)
  • Gear ratio: 1:48
Dimensions (mm)
Use with plastic timing pulley
1280X1280_-_2023-03-02T173336.095.PNG1280X1280_-_2023-03-02T173342.342.PNG1280X1280_-_2023-03-02T173346.324.PNG1280X1280_-_2023-03-02T173350.718.PNG
11 out of 16 found this helpful
