About mBot2/Neo Shield
Overview
mBot2 Shield is equipped with a built-in rechargeable lithium-ion battery that can supply power for CyberPi. With the multi-function, servo, and motor ports, it can drive motors, servos, and LED strips.
Features
  • Built-in rechargeable lithium-ion battery, used to supply power for CyberPi
  • Two multi-function ports, used to connect and drive not only servos but also LED strips
  • Two servo ports, used to connect and drive servos
  • Two DC motor ports, used to connect and drive DC motors
  • Two encoder motor ports, used to connect and drive encoder motors
  • One CyberPi port, allowing you to easily connect mBot2 to CyberPi
  • Supporting Python programming, for which the cyberpi library is provided
Specifications
Specification Description
Microprocessor GD32F403
Battery
3.7 V, 2500 mAh
Packaging: Bundle (battery included)
Battery type: Lithium-ion polymer battery
Battery weight: 44.6 g
Watt hours per battery (wh): 9.25 wh
Lithium content: 1.07 g
Lithium battery voltage: 3.7 V
Input voltage and current 5 V, 2000 mA (fast charging)5 V, 500 mA (charging in operation)
Output voltage and current 5 V, 6 A
Battery life 3–6 hours (in general application scenarios, just for reference)
Charging time 80 minutes (in fast charging mode)
Battery endurance The capacity of the battery is remained at 70% or higher after it is charged and used for 800 times (at 20±5℃, 0.2 C discharging).
Communication mode
Serial communication: between the main control board and extension board
Digital signals: at the digital servo port
PWM signals: at the DC motor port
Hardware version V1.0
Note:
  • Self-discharge occurs in the lithium-ion battery. If you store mBot2 Shield with the battery voltage lower than 3.6 V for a long time, the battery will be over-discharged and its internal structure may be damaged, which reduces the endurance of the battery. Therefore, to store mBot2 Shield for a long time while keeping the battery intact, you need to charge the battery once every three to six months to 3.8–3.9 V (the best voltage for storage is 3.85 V), which allows the discharge depth of 40% to 60%.
  • Store mBot2 Shield at 4℃ to 35℃ in a dry place or keep it away from moisture through packaging.
  • Keep it away from heat or direct sunlight.
Programming
You can use mBlock 5 to program mBot2. mBlock 5 provides two editors, namely the block-based graphical editor (the default editor, referred to as mBlock 5) and Python editor (referred to as mBlock-Python Editor).
For details about programming, see "Program mBot Neo with mBlock 5."
15 out of 16 found this helpful
