About MegaPi Encoder/DC Driver V1
Overview
MegaPi Encoder/DC Motor Driver V 1 can drive two DC motors or one encoder motor. It adopts the 2 × 8 pin connection mode and thus can be easily mounted on MegaPi.
Specifications
  • Motor driver: MP80495
  • Number of motor channels: 2
  • Minimum operating voltage: 6V
  • Maximum operating voltage: 12V
  • Logical voltage: 5V
  • Rated operating current of each channel: 3A
  • Peak operating current: 5.5A
  • Dimensions: 30 mm x 15 mm (width × height)
Features
  • Supports motors with an operating voltage range of 6V to 12V
  • Provides a maximum operating current of 3A (a maximum peak operating current of 5.5A) when the power supply is 12V
  • Equipped with overvoltage, overcurrent, and overtemperature protection, which ensures safe application
  • High rotating speed at start
  • Provides the offline function
  • Photoelectric isolated signal input/output
  • Provides the overvoltage, undervoltage, overcurrent, and phase-to-phase short-circuit protection
Connection
6 out of 12 found this helpful
3 comments
  • Je ne sais pas ce produit car il est chinois est que c’est l’éclattaxe
  • mais je suis totalement d'acor
  • je suis pas dacor voiyon se produit permet de se lebron james
