About Photoelectric Encoder Motor 180 RPM (for mBot Ranger)
Overview
Photoelectric encoder is used in the photoelectric encoder motor 180RPM for high-precision control. It can be flexibly used with other parts. There are two M4 threaded holes on three sides of the motor respectively, so it can be easily fixed with Makeblock mechanical parts. Meanwhile, the noise is low when the motor is running and large torque is available for a long time since customized material is used. The motor supports multiple motor drivers and main control boards, such as Orion, MegaPi, MegaPi Pro, and Me Auriga.
Specifications
  • Reduction gear ratio: 39.6
  • Rated voltage: 7.4 V
  • No-load current: 240 mA
  • Load current: ≤ 750 mA
  • No-load speed: 350 ± 5% (RPM)
  • Original speed: 14,000 ± 5% (RPM)
  • Start torque: 5 kg·cm
  • Rated torque: 800 g·cm
  • Length of the output shaft: 9 mm
  • Power: 3.7 W
  • Encoder rotation angle: 360°
Programming Guide
● Program with mBlock 5
Block description (main control board: Auriga)
Block Features
output__2_.png Select a port
Set the power to -100–100
output__3_.png Select a port
Set the speed (the maximum speed depends on the motor model)
output__4_.png Select a port
Set the rotation angle (a natural number)
output__5_.png Obtain the speed of the motor
output__6_.png Obtain the angle of the motor from the origin
After the following program runs, encoder motor 1 and encoder motor 2 rotate at the speed of 100 RPM for 1 second and stop rotating for 1 second, and then repeat this process.
● Program with mBlock 3
Block description
Block Features
output__7_.png Select a slot
Set the power to -255–255
output__8_.png Select a slot
output__9_.png Select a slot
output__11_.png Obtain the speed of the motor
output__12_.png Obtain the position or degree of the motor from the origin
● Program in Arduino
If you program in Arduino, you need to use Makeblock-Library-master to control the motor.
#include <Arduino.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <MeMegaPiPro.h>
double angle_rad = PI/180.0;
double angle_deg = 180.0/PI;
MeEncoderOnBoard Encoder_1(SLOT1);
MeEncoderOnBoard Encoder_2(SLOT2);
void isr_process_encoder1(void)
if(digitalRead(Encoder_1.getPortB()) == 0){
Encoder_1.pulsePosMinus();
}else{
Encoder_1.pulsePosPlus();
void isr_process_encoder2(void)
if(digitalRead(Encoder_2.getPortB()) == 0){
Encoder_2.pulsePosMinus();
}else{
Encoder_2.pulsePosPlus();
void setup(){
TCCR1A = _BV(WGM10);//PIN12
TCCR1B = _BV(CS11) | _BV(CS10) | _BV(WGM12);
TCCR2A = _BV(WGM21) | _BV(WGM20);//PIN8
TCCR2B = _BV(CS22);
attachInterrupt(Encoder_1.getIntNum(), isr_process_encoder1, RISING);
attachInterrupt(Encoder_2.getIntNum(), isr_process_encoder2, RISING);
void loop(){
Encoder_1.setTarPWM(100);
Encoder_2.setTarPWM(100);
delay(1);
Encoder_1.setTarPWM(0);
Encoder_2.setTarPWM(0);
delay(1);
loop();
● Program in Python
  1. Install MegaPi Pro on Raspberry Pi, and connect the photoelectric encoder motor 180 RPM to the DC/encoder driver.
  2. Install the latest Makeblock library for Raspberry Pi, do a “pip3 install makeblock” in the command line, and then do an “upgrade” in the command line.
  3. Create a Python file suffixed with .py.
  4. Write a program in the Python file.
  5. Run the Python file, for example, “python123.py”.
Function description
Function Feature
EncoderMotor(port) Set a port to connect the DC/encoder motor. port: MegaPiPro.PORT1~MegaPiPro.PORT4
run(speed) Rotate at the specified speed. speed: rotation speed range: -180–180
move_to(position,speed,callback) Rotate to the specified position at the specified speed. position: target position speed: rotation speed (range: -180–180)
callback: callback is triggered when the target position is reached
set_home() Set the current position as the origin.
Example program 1:
After the following program runs, the encoder motor connected to port 1 for DC/encoder motor on MegaPi Pro rotates clockwise at the speed of 50 RPM for 2 seconds, stops rotating for 1 second, rotates anticlockwise at the speed of 50 RPM for 2 seconds, stops rotating for 1 second, and then repeats this process.
from time import sleep
from makeblock import MegaPiPro
board = MegaPiPro.create()
encoder = board.EncoderMotor(MegaPiPro.PORT1)
while True:
encoder.run(50)
sleep(2)
encoder.run(0)
sleep(1)
encoder.run(-50)
sleep(2)
encoder.run(0)
sleep(1)
Example program 2:
After the following program runs, the encoder motor connected to port 1 for DC/encoder motor on MegaPi Pro rotates to the target position.
10 lines (9 sloc) 274 Bytes
RawBlameHistory
position = 0
def on_finished(value):
position = 5000 - position
encoder.move_to(position,100,on_finished)
on_finished(position)
Wiring Mode
● Connect electronic modules
Connect the photoelectric encoder motor 180 RPM to the port for encoder motor on the main control board or the port for encoder motor on the encoder motor driver by using the cable for photoelectric encoder motor 180 RPM.
● Build the structure
The photoelectric encoder motor 180 RPM can be used to provide power or used as a part of the chassis of mBot Ranger. Its shaft is compatible with the plastic timing pulley 62T with step and the plastic timing pulley 90T with step on Maker’s Platform of Makeblock.
0 out of 0 found this helpful
