Case 8 - Basic movements
Part 1 Objective
After you write the program and upload it to mBot, your mBot moves forward, moves backward, turns left, turns right, and then stops moving once it is started.
Part 2 Preparation
  • mBot x 1
  • USB cable (Type-B) x 1
  1. Connect mBot to the computer by using the cable.
  1. Open mBlock 5 (PC client or web version), click +add in the lower left Devices area, select mBot from the Device Library, click Connect, and select the Upload mode. (Live mode: you can click on the blocks to see the real-time running effect, but you need to keep the cable connected to the computer. Upload mode: you can upload a program to mBot, and you can unplug the cable to run the program.)
Part 3 Programming
After you upload the program to mBot, your mBot moves forward, moves backward, turns left, turns right, and then stops moving once it is started.
Script image
Part 4 Project file
8.Basic movements.mblock
Part 5 Practice
  1. Change the duration of the movements to make your mBot move further.
  1. Program with other Action blocks and see how your mBot moves.
4 out of 12 found this helpful
1 comment
  • You haven't included reference to MLink and how to add to laptops and Chromebooks.
