Part 1 Objective
User writes a program to achieve that when the mBot starts, the mBot moves forward, backward, turns left and right in turn, and finally stops moving.
Part 2 Preparation
mBot x1
USB cable x1
Computer with network access
Use a data cable to connect the mBot to the computer.
Open MBlock5 (PC, Web, APP), click "Add" in the lower left device area, select mBot in the device library, and click “Connect”.(Live mode: you can click the building block to observe the real-time running effect, but you need to keep the data cable connected to the computer; Upload mode: You can upload the program to mBot, at which time you can unplug the data cable to run the program. ), this course needs to switch to "Upload mode".
Part 3 Programming
User uploads the program to make the mBot stop moving after going forward, backward, left, and right turns.
Source program diagram
Part 4 Procedure source code
Part 5 Practice
Modify the movement time value in the blocks to make the mBot go further.
Try other motion module blocks and observe the operation effect of mBot.
