Case 6 - Read the value of ultrasonic
Part 1 Objective
User writes a program to display the real-time distance value detected by the external ultrasonic sensor in the stage area of the computer.
Part 2 Preparation
  • mBot x1
  • USB cable x1
  • Computer with network access
  1. Use a data cable to connect the mBot to the computer.
  1. Open MBlock5 (PC, Web, APP), click "Add" in the lower left device area, select mBot in the device library, and click “Connect”.(Live mode: you can click the building block to observe the real-time running effect, but you need to keep the data cable connected to the computer; Upload mode: You can upload the program to mBot, at which time you can unplug the data cable to run the program. ), this course needs to switch to "Live mode".
Part 3 Programming
Create a new variable and rename it to "Distance" to store the distance value of the ultrasonic detection, select it to display in real time in the stage area. Note that the interface number that matches the sensor connection interface is selected.
Source program diagram
Part 4 Procedure source code
Get the distance value.mblock
Part 5 Practice
  1. Set the distance value detected by the ultrasonic sensor as an integer
  1. Use ultrasonic sensors to measure the length of an object
0 out of 1 found this helpful
