Part 1 Objective
User writes a program to display the real-time readings of the on-board light sensor on the mBlock stage area when changing the ambient light around the light sensor.
Part 2 Preparation
mBot x1
USB cable x1
Computer with network access
Use a data cable to connect the mBot to the computer.
Open MBlock5 (PC, Web, APP), click "Add" in the lower left device area, select mBot in the device library, and click “Connect”.(Live mode: you can click the building block to observe the real-time running effect, but you need to keep the data cable connected to the computer; Upload mode: You can upload the program to mBot, at which time you can unplug the data cable to run the program. ), this course needs to switch to "Live mode".
Part 3 Programming
Create a new variable and name it Light Intensity to store the detected light intensity value and select it to display in real time on the stage area.
Source program diagram
Part 4 Procedure source code
get light intensity value.mblock
Part 5 Practice
Increase the time value in the Waiting Block to slow down the change in the light sensor value and make user see more clearly.
Ask Panda to describe the real-time intensity of light detected by the current light sensor.
