Part 1 Objective
User writes the program and uploads the program to mBot, which will activate the key recognition function, so that it can determine whether to press the key and play the note after pressing the key.
Part 2 Preparation
mBot x1
USB cable x1
Computer with network access
Use a data cable to connect the mBot to the computer
Open MBlock5 (PC, Web, APP), click "Add" in the lower left device area, select mBot in the device library, and click “Connect”.(Live mode: you can click the building block to observe the real-time running effect, but you need to keep the data cable connected to the computer; Upload mode: You can upload the program to mBot, at which time you can unplug the data cable to run the program. ), this course needs to switch to "Upload mode".
Part 3 Programming
After the user uploads the program to the mBot, the mBot will play the corresponding musical note whenever the User presses the black button on the board.
Source program diagram
Part 4 Procedure source code
Lesson 3_Playing notes by key.mblock
Part 5 Practice
Change the type of musical note
Change the musical meter
