Case 2 - Random-color LEDs blink
Part 1 Objective
After you write the program and upload it to mBot, you can turn on your mBot with random-color LEDs blinking.
Part 2 Preparation
  • mBot x 1
  • USB cable (Type-B) x 1
  1. Connect mBot to the computer by using the cable.
  1. Open mBlock 5 (PC client or web version), click +add in the lower left Devices area, select mBot from the Device Library, click Connect, and select the Upload mode. (Live mode: you can click on the blocks to see the real-time running effect, but you need to keep the cable connected to the computer. Upload mode: you can upload a program to mBot, and you can unplug the cable to run the program.)
Part 3 Programming
After you upload the program to mBot, the on-board LEDs light up with random colors.
Script image
Part 4 Project file
2.Random-color LEDs blink.mblock
Part 5 Practice
  1. Modify the values of the random numbers.
  1. Modify the time interval.
2 out of 3 found this helpful
