Case 1 - LEDs blink
Part 1 Objective
After you write the program and upload it to mBot, your mBot has basic lighting capabilities.
Part 2 Preparation
  • mBot x 1
  • USB cable (Type-B) x 1
  1. Connect mBot to the computer by using the cable.
  1. Open mBlock 5 (PC client or web version), click +add in the lower left Devices area, select mBot from the Device Library, click Connect, and select the Upload mode. (Live mode: you can click on the blocks to see the real-time program running effect, but you need to keep the cable connected to the computer. Upload mode: you can upload a program to mBot, and you can run the program after you unplug the cable.)
Part 3 Programming
After you upload the program to mBot, the LEDs blink in three colors successively and repeatedly.
Script image
Part 4 Project file
1.LEDs blink.mblock
Part 5 Practice
  1. Change the blinking frequency of the LEDs.
  1. Change the color of the LEDs.
  1. Increase/decrease the number of colors.
13 out of 17 found this helpful
